Cropfactor for DJI Air 2s
PicPerf
Germany
I am trying to figure out the cropfactor of the DJI Air 2s cmos sensor. They write the 35mm equivalent focal length is 22mm. A picture that I took tells me the sensor size is 5472 x 3648 pixels. Each pixel is square-shaped and with size 2.4 mu. This gives a physical size of 13.1328 mm x 8.7552mm. From pythagoras I calculate a diagonal of 15.78mm. This is not equal to 1 inch (25.4mm). Can anybody help here?
You might want to check out an earlier thread on the sensor sizes
Assuming your math is correct, maximum photo/video resolution is not always equal to sensor size.
The sensor may have more photosites (not pixels) than final maximum resolution in a couple different ways:
1) The full number of photosites on the sensor may not be captured - some designed-in slop at the edges that is cropped out. This would typically be slight.
2) There may be many more photosites on the sensor than in the final image, which are processed to a lower resolution before recording.
This could happen in a couple ways:
Pixel binning, in which data from some photosites in the active imaging area of the sensor is not included;
or resolution reduction during image processing, in which e.g. a 6k image may be reduced in resolution to 4k in the camera image processing before recording.
I don’t know specifically what’s going on in the sensor and image processing of an Air2S. The engineering is interesting. In my opinion if it looks good it is good.
EDIT
My reply crossed with @anotherlab above. I re-read the earlier thread they linked, this popped out as a major third factor:
Notation for sensor size is a whole big can of worms. Basically, the published numbers are usually just a marketing gimmick based on decades old notation called 'optical format' owing back to when camera sensors were based on vacuum tubes…
You are not the first to be confused about the naming of sensor sizes. A 1-inch sensor is not 1 inch in diagonal, as you found out.
Here is the explanation why:
Reactions: wisefish
djimini3
