CrystalSky MavMount bracket screw upgrade
Very nice. Good idea and thanks for sharing. Will have to get some of these for our in-house units as we're constantly demoing and switching CS units from Mavic, Spark, Phantom, Inspire and Matrice units all day which most all have different mounting solutions. Cheers!
Reactions: Aerial West
While those thumbscrews work great, I've found out today that the lanyard plate gets in the way of the bottom USB cable port :(
Yep, you are correct. It puts pressure on the cable otherwise. Not a good design. I just clipped the strap to the main base plate. It's not balanced, but it will allow for hands off if necessary.
Replace the C cable with a right angled one that should sort it out.
Guys,
I tested a lot of mounts. Incl. the expensive and famous Mavmount. But the best for me is a cheap one on Aliexpress.
Good thing is that the screws we are talking about are included.
I thought it would be plastic, but all the parts are from metal.
The mount is lighter than the Mavmount. So that one i don't use anymore...
Just for you information: Bracket Mount Adapter Houder Stand voor DJI Mavic Pro/Spark Drone 5.5/7.85 'voor DJI CrystalSky Monitor accessoires in Bracket Mount Adapter Houder Stand voor DJI Mavic Pro/Spark Drone 5.5/7.85 'voor DJI CrystalSky Monitor accessoires van Drone Accessoires Kits op AliExpress.com | Alibaba Groep
Peter
KevinC
