Yes it is. GO4 app on the CS supports Mavic AIR.if the Crystalsky monitor is compatible with the Mavic Air?
As Keule wrote the CS works perfectly with Mavic Air.Hi, can any of you good people tell me if the Crystalsky monitor is compatible with the Mavic Air?
To mount the CrystalSky to your RC, you have to buy a 3rd party mount.
You can also exchange the 2 folding arms against the Mavic PRO arms, then the original DJI mount will fit.
But please note there is no charger included with the Crystalsky and the Mavic Air charger is not compatible with the included Crystalsky Charging Hub. Several Inspire and Phantom chargers are compatible. I would recommend the Phantom 3 57W charger A14-057N1A which is quite compact and light (some of the more powerful Phantom and Inspire chargers are really heavy and bulky).
I am using DJI's Remote CrystalSky mount on a 3D printed baseplate.Can I ask which mount you use with yours?
I use the PolarPro CrystalSky mount which works well. But I'm planning to add the DJI CrystalSky RC Mounting Bracket to it instead of the PolarPro top part. The DJI quick release is a nice solution.I wonder why DJI Customer Support would tell that it was not yet compatible? Can I ask which mount you use with yours? Thanks again.
Yes it is. I've been using the 5.5" model for about 6 months now.Hi, can any of you good people tell me if the Crystalsky monitor is compatible with the Mavic Air?
FYI.....Drone World has Phantom 4 chargers, which can be used to charge the CS battery, on sale.As Keule wrote the CS works perfectly with Mavic Air.
