Custom style numbers wont change
globalbum
I am using the custom setting under style and the numbers will not change. I hit each spot with my finger and then the up down button to change the number but no luck. What am i doing wrong? Thanks
Many of the settings are not adjustable unless the you are connected to the aircraft. Connect it and it should work for you.
DigitalJoe
