Dashware on the Mini 4 Pro
Exphantomflyer
Manchester UK
I know its usually 120ccpm that does the dashware stuff for the forum but I think he may be busy with other things.
Here is a zip file and some gauges, most are just adaptations of original works by 120ccpm so credit goes to him.
Instructions
obtain the flight log, this can be found on the DJI RC2 , plug your controller into your PC and navigate to PC\DJI RC 2\Internal shared storage\Android\data\dji.go.v5\files\FlightRecord
Once yo have that you need to convert it to a CSV file , this can be done by signing upto AIrdata.com
Upload the flight log then go to Mylogs Flights and click on the left side, once done click CSV under the map.
Install Dashware using the install file in the zip folder https://www.dropbox.com/scl/fi/l ... t=lqz2op6x&dl=0
Instructions for Dashware are on the web so i wont go into detail here.
Enjoy
Reactions: chadCO
Instructions
Enjoy
Also just finished the files using a log file courtesy of MSingers Phantom log viewer webpage
Hello Exphantomflyer
I am trying to get the DashWare working and everything seems to be OK until I add th e.csv file fomr AirData and select the DJIMini4 Data profile and I get this error: 1764084250534.png
Any Ideea? I am attaching the csv file.
I am trying to get the DashWare working and everything seems to be OK until I add th e.csv file fomr AirData and select the DJIMini4 Data profile and I get this error: View attachment 186618
Any Ideea? I am attaching the csv file.]
seems the file copy isnt working using the batch file so copy these files over to the relevant directory
copy DJIV7.xml documents\Dashware\DataProfiles
copy CustomDataTypes.xml documents\Dashware\Settings
Then try again
I se you are using a different file: DJIV7.xml where did you get that from?
from the original dropbox link I just edited it now and uploaded it, I think you have downloaded the phantom help rar file version which is djiv4
There were a few versions, ill get around to doing a post tidy up and check the files this weekend, if you have issues email me at [email protected] for a quicker response
utahloanrelief
