Disconection Issues with MA after the latest DJI go4 update on 21st May 2018
I found out the main issue. It's the Micro USB cable end that connect to the RC became loosen. So once you accidentally touch it will disconnect the App and RC. Replace or fix it . No more disconnection.
Im having same problem not all the time 3 times happened even when unpugged the phone and plugged back in had not video feed had to turn off controller and back on while in air. Its not cable problem tested it plus tried using the usb port under the controller same problem. Im using samsung s9+ im going to downgrade firmware since using the latest and have had these problems since then dont know if have to also downgrade controller firmware?
Not the new firmware ...I had the same issue before update..exactly ..so it's a glitch they still have not fixed..if it happens again..switch to sport mode and it works fine afterwards...like a reset ..I sold my MA ..even though I loved it..it was too loud for my neighborhood..Mavic Pro..is good enough for me..
I had two similar video lockups after using active track with my MA, but have not experienced this since. I use an iPhone 6.
I had a similar experience for the first time yesterday. I was in wide open, mostly flat ground and went out 8000ft. and was returning on the same route and elevation with about 4500 ft. to go when I suddenly lost all video and telemetry. This was no typical signal loss due to distance or obstacles that I've seen before. I rebooted the controller and immediately got a connection. The drone did appear to have started an RTH by backtracking the route initially. But I cancelled the RTH and flew it home in sport mode with no further issue. I also flew for about an hour today with no issues.
this is exactly what happned to me.
mrdavidsmith
