- Joined
- Feb 8, 2017
- Messages
- 193
- Reactions
- 175
- Age
- 48
Just launched and got about 30 ft away and 80 ft up. App said aircraft disconnected, but controller display looked normal. Mavic became unresponsive, and I am assuming it initiated a RTH because it came back and hovered about 5 ft off the ground above take off.
The entire time the r/c read GPS mode but I had no control. I then restarted the app and controller finally read disconnected instead of GPS. A moment later it reconnected and I regained control. I landed and power cycled everything.
I didn't take off again, but tried several different spots around the yard and the problem persisted. App showed disconnect and about 45 seconds later r/c showed disconnected and flight status indicator blinked rapid yellow.
Is it normal for such a delay between losing connection and the controller displaying it?
Not to mention losing connection from 5 ft away.
I am using samsung note 5 and DJIGo4. I have Go3 installed for osmo mobile. I did delete both and reinstalled go4 only. Waiting for the wife to get home because my 2 year old is awake now. Running out of daylight.
Thanks in advance.
P.S. I had trouble with the f/w update but flew on Sunday 3 flights for 45 minutes with no issues after the update.
Thanks in advance.
