Distance to Home and Distance to aircraft
That must be great ! But I thought that CE mode prevented the drone to go further than 4 Kms
That can’t be right, what about those of us that use iPads without inbuilt GPS?
Then all you will see is the distance from home point which is determined by the quad.
Also in the app if you try to set the homepoint as your location the app will tell you that your GPS signal is to weak.
captainscottyy
