DJI Air 3s Crashed in to a Wall | Advice needed!
Ray17
sri lanka
Hi, I’m new to flying drones. I recently got my DJI Air 3S in Sri Lanka, where DJI Care Refresh is not available.
I wasn’t using propeller guards at the time, and the drone was in cinematic mode. Because it was a tight corner I turned off the sensors. It first hit its propeller on a wall and then fell onto hard concrete from about 5 feet. As soon as it crashed, the controller displayed a message saying: “Collision detected. Change the propellers if damaged.”
Here are the images of the crashed drone
All four propellers were damaged, and the drone has some scratches on its back. There are also scratches on one of the motors, and some small metal chips were shaved off.
I replaced the propellers and did a test flight. The drone works fine—there are no errors on the controller, and the gimbal, stabilization, and flight controls all seem normal. However, I’m worried about potential issues in the future.
Sending the drone for inspection isn’t an option because the cost would be nearly the same as buying a brand-new one. Is there a way for me to diagnose it myself?
As experienced drone pilots, do you think it’s safe for me to keep flying without worrying? This drone is my entire savings, and I’m only 17 years old.
Here are the images
Reactions: RodPad and Cafguy
You need to fly carefully for the first couple of flights after a crash. You may in the near future get a strange error BUT if it seems to fly just fine and you see nothing wrong then I would consider it a cheap lesson learned and fly normally without worry after that.
The air 3S isnt much of an indoor Drone. Take it outside... ;)
Regarding your "Advice Needed!" request,
  • Leave the obstacle avoidance features in operation.
  • Never rely on the obstacle avoidance features to keep you out of trouble.
  • Don't fly near objects, at least until you have several dozen hours of flight time and understand the risks.
Regarding the airworthiness of your drone,
  • Inspect the entire drone very carefully for possible damage. Open and close the motor arms and check for roughness, noises, improper motion, ... Check the battery and the battery latching mechanism carefully.
  • Make several flights exercising the drone and observing any irregularities, odd noises, and such.
  • Shoot some photos and videos to check the camera functions.
  • Verify that all functions involving sensors and OA cameras are working properly - reaction to obstacles, proximity indicators, alternate black & white views, ...
Explain what you mean by "There are also scratches on one of the motors, and some small metal chips were shaved off."
This sounds potentially problematic. Where was the metal damage? Were the fragments actually chips, or were they shavings?
Here are the images
....lucky. Best advice? Save up and buy a set of prop guards just in case you have to fly in tight spaces at some point in the future.
Reactions: RodPad
Yes, and you did, and it's fine. Fly with confidence.
Just remember that the circumstances under which it crashed were extremely risky for that model and class of drone... If you need footage under those circumstances, use an Avata 2, and if the camera's not good enough, strap a GoPro to it.
The Air 3S is NOT designed for close-quarters flight, and prop guards are a mean trick to get you to think they'll actually protect the drone 😁
Here are the images
Hi there... If is working, it will be good all the way..Don't worry, carry on, keep sensors on at all times..
That "...mean trick..." Earned it's keep 40 times over with just one close encounter with a stone wall.
Simple economics: cost of prop guards: £30. Cost of Mavic 2: £1,200. Mine carried on flying for the last four years when it should have been a twisted pile of plastic. If what I'm trying to get a shot of requires 'up-close-and-personal': the PGYTECH guards get clipped on.
I believe you have learned a valuable lesson here.
Avoid New Pilot errors by
1. flying in an open space without obstacles
2. Never turn off obstacle avoidance
Your drone looks fine based on the photos. You got lucky this time. I would follow all the advice given you
@Ray17
At the moment, I think you got a good early warning.
I been there?
Welcome to the forum!
Here is one of my lines for new flyers.
Good day, can go bad really fast!
Been there :rolleyes:
Rod ..
Here are the images
As a fellow teen pilot, (that has also crashed his fair share of drones over 9 years of flying.) I would say the drone is most likely fine, just keep an eye out for any odd errors/behavior. A few years ago, I crashed my Mavic Mini into a tree at 17mph, where it dropped onto concrete from about 7-8 feet up. A few scratches and scuffs later, a change of props, and it was back to flying just fine, mind you with a few battle scars. 😅
Reactions: RodPad
Here are the images
I learned to fly a toy drone because I thought it might help if my Mavic pro lost satellite connection.
Here are the images
Definitely a risky flight at your experience level. I sometimes have to turn off obstacle avoidance to land in tight spaces, but try to keep it on.
Sorry to read but the Air 3S is for open spaces.
May I suggest that you also get a NEO for tight places and for practice?
The NEO is practically indestructible and cheap to replace if ever you do.
Gavthistle
