DJI assistant turns off my laptop wifi every time I connect the Air2s USB
AnDronioBanderos
Ireland
Hi Guys
Can anyone help?
I have DJI assistant consumer series on Windows 10 and every time I connect the air 2S usb cable, it turns off my wifi?
Once I unplug it my wifi turns back on.
Drone shows up as a connected device and everything. But turns off wifi :(
It does not happen when I connect the DJI controller and shows firmware correctly.
Anyone else have this or know whats happening? I have tried everything
thanks for your help.
Hi Guys
Can anyone help?
Finally managed to fix this.
If anyone is having the same problem you need to connect the drone then for some reason reason mine as defaulting to a non existent ethernet connection.
I finally got to change this and it then stayed connected to wi-fi.
Possibly a Windows thing.
HI, I'm having the issue. Could you elaborate on what you did to fix it please? Thanks!
O'Ryan
