DJI Flight Simulator
sludge
Has anyone tried it. Is it even worth the download of the trial?
There is another thread about it mate. FWIW very tempremental and you need a hi end gaming computer to use it.
Reactions: Porky
Not good. OK so I won’t bother with it. Also read that the MP1 RC is not supported.
If you have the right computer, it runs just fine. The flying experience in the trial is similar to the DJI GO flight simulator. If you don't enjoy that, then you likely won't enjoy this one either.
The required computer specs are pretty high-end though as @Simmo noted above. When using the average computer, it'll likely freeze a lot and possibly even crash.
If you'd like to see what it looks like, check out some videos here on YouTube.
So I tried to install it but it fails repeatedly to install.
Try going into your directory, program files x86, find dji flight simulator and run dji_usb_5512_64_108.exe
Then try to instal it again.
You didn't get it running at all???
That exe file just installs drivers, and at least the sim should work?
But after that, I gave up too, coz my PC is not good enough to run it!!!
No, it is not compatible with Mavic Pro!
Umrahtaxiservice
