DJI GO 4 tells me I must update to 4.1.3
mlash
Is this normal? I would think that there should be a "not now" button here somewhere. I turned on my wi-fi so I could upload my logs and this popped up and will not let me continue until I update! If I do update to this is it going to force me to update controller and aircraft? I am currently on .0400 and I don't want to update to current firmware.
Has anyone gotten this yet? It will not go away!
Did you try "force close/block notification/manual update only" on settings?
Sorry just an idea.
This message is about updating the app on your device - Not the Mavics firmware
Thanks for your help! Is this the update that one must sign back into or the aircraft is limited?
That change was made in a firmware update.
Is this normal? I would think that there should be a "not now" button here somewhere. I turned on my wi-fi so I could upload my logs and this popped up and will not let me continue until I update! If I do update to this is it going to force me to update controller and aircraft? I am currently on .0400 and I don't want to update to current firmware.Has anyone gotten this yet? It will not go away!
You can wokraround it ..
Interesting article. The big problem with dji is that their no fly zones aren't accurate and dji doesn't correct the inconsistencies and incorrect NFZ. If dji was on top of there restrictions and have them be correct then people would have no problem with it. To apply to fly in a NFZ when it shouldn't be a NFZ and take 3 days for approvals is crazy.
I had a problem one time when it said my return to home would fly through a NFZ and to modify my flight path. And i wasn't even near a NFZ. It could of auto landed incorrectly and I could of lost my drone.
Reactions: jash123 and beerguy
Interesting article. The big problem with dji is that their no fly zones aren't accurate and dji doesn't correct the inconsistencies and incorrect NFZ. If dji was on top of there restrictions and have them be correct then people would have no problem with it. To apply to fly in a NFZ when it should be a NFZ and take 3 days for approvals is crazy.
Wow thats crazy, Restricted airspace is okay just NFZ's? I fly in class d airspace pretty regularly. What other limitations are there? Whats the altitude limit? I am going to the Maldives, am i going to have problems using it there? I am a noob so thanks for your help
ETinVT
