DJI Goggles Racing Edition boot stucked
1. Make sure the cable is the right one
2. Reinstall the DJI assistant to the latest if you have that delete and reinstall
3. Did you select the correct port?
4. The connector inside the goggles needs to be repaired.
1, Checked, working well.
2, Done, nothing changed.
3, Absolutely!!!
4, Which connector? The USB port working, the Goggles charging, but the software not booting. Stuck on the DJI logo screen.
I hope somebody can tell me a trick, how can reflash it.
Reactions: Cafguy
I will ask someone else I have a pair of the RE editions never had them do that to me tho
DID you factory reset them!
If you are seeing only the DJI screen in the goggles I am told to turn them on and let them drain completely ( Hard Reset)
it could be a faulty connector they are bad in these goggles I would try the hard reset and start from scratch.
Hope it Works, let me Know.
A hard reset is simply turning on the goggles and letting the batterie run until the goggles die. do not turn them off let them die. This will reset the goggles then you may be able to get past the DJI screen if so in the goggles menu go to ABOUT and then Reset ALL.......
Did this work? let me know.
The Goggles turned off, but when I hit the power button, the first led is blinking. How can I drain complatly to make a hard reset?
No point letting them drain, if you wanted to cut all power just disconnect the head strap. Since it's designed for it it's going to do a whole lot of nothing.
Unlikely there's anything you can do though...
I would like to do a hard reset. So enough to drain it until it turn off.
I done the drain, keep it for a night in that status.
Now started to charge and turned on. Still stucked on the logo screen. :(
kaidoestech
