Dji goggles
Hayabusa
thinking about getting a pair of the standard versions. Any reason not to or only the RE versions?
Plus can I use these on any other fpv race drone. I would like a pair I can use for both if possible. I assume the dji goggles would be better than let’s say fatsharks etc..
Mike
Have a look at the Epson Moverio BT-300 as well, much lighter and a smaller form factor than the DJI goggles.
Also they mixed reality so you can still see the drone via VLOS
Reactions: SSurogate2017
I wear glasses as well so not sure about those.
Thanks
There are also issues with glasses and the DJI Goggles, the BT-300 has inserts for a prescription and also a nose bridge extension that pushes the frames further out, which then allows some glasses to sit behind them.
Rochester Optical in the U.S has a slightly different option
Smart Glasses Optimized Lens Designs (Smart GOLD) Lenses for Epson BT-300
Even though I am short sighted I don't find I need the glasses as the screen image is in the distance and magnified
joel_du05
