DJI mavic mini 2 propellers out of sync so does not take off
monishj
manchester,NH
Hi
i am having trouble with taking off as right side front propeller seems to be out of sync. Any help in this matter is appreciated
Hi
Define out of sync. Do you mean not the same speed? If so your broken/defective and need a repair. Most normally, in the situation as you fail to describe in detail...is caused by user error with DJI's latest offerings and you have one or more props on wrong.
Reactions: RMS001
@monishj what you describe is a classic case of the wrong props on one or more of the motors
if on the other hand you have not removed any of them and the drone flew ok before
then its probably time to contact DJI or if you bought it locally or from Amazon for instance then use their return policy and get a replacement
Reactions: Zeke
thank you Sir for the advice.It is a user error. I did not put the props right.
And ty for your service !
Thank you !
markus94
