DJI mini 2
Hello from the Crossroads of America manikandan
I don't have a Mini 2 so I probably can't help you.
There are settings in the app that may limit your height?
Other Mini 2 flyers may chime in soon and have more insight.
Good luck and welcome to the Forum. :cool:
My drone is not flying
I fly a Mini 2 and if you have not set your Maximum Altitude to this low altitude then I cannot help you. I have never tried flying in "practice Mode" (What ever that is, I've never heard of it on the Mini 2...) or without logging into my DJI Account… so All I can say is good luck.
Since you live in India, there are specific laws and rules for you to follow, please check to ensure these are current.
You also seem to be a newbie so here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Henrik, welcome to the forum from Hauptmann in North Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before!
Our more than 150,000 members worldwide enjoy helping each other get the most out of our hobby. Many of the questions you'll have will have already been addressed, and are easy to search. New questions? Just ask!
As to your height/range issue: 1. Log into your DJI account; 2. Make sure you are not in "Practice Mode'; 3. Reset your Height and Range limits.
Glad to have you with us!
Rich R (aka Hauptmann)
p.s. Be sure to follow LoudThunder's advice.
My drone is not flying above 15 miter how will try to fly to 120 miter plz
Sounds like it has gone to ”Payload” mode. Find the “Advanced Settings” line in the DJI Fly software, open it, and there will be a slider button that is engaged. Slide it to OFF and you’ll be able to fly past the altitude and distance limits that you’re seeing.
rstegner
