It seems that the Dji RC for Mini 3 Pro will soon be made to work with the Mavic 3 with an upcoming update. For those that have the RC N1 and Mavic 3, will you be buying the Dji RC as well? |
Yup but maybe Rc Pro not selling muchSurely that would torpedo future RC Pro sales, wouldn't it?
And some people report zero issues. I run out of electrons before I run out of feet with the DJI RC. Yes my RC Pro has more power, but I wouldn't listen too much to all the hype regarding lack of range. /$.02This remote has built-in antennae and I think that's a bad design choice. There are already some people reporting that its signal strength is not as good as that of RC-N1 or RC Pro. I was waiting for a remote like this, but not on the expense of signal strength.
I'm just saying that built-in antennae is not a good design choice with respect to signal strength. I do not "listen to the hype", but if signal strength is not as good, I would not be surprised. That's why I will wait for more people to use it and share their findings. If there are any such issues we will most probably read about them somewhere.And some people report zero issues. I run out of electrons before I run out of feet with the DJI RC. Yes my RC Pro has more power, but I wouldn't listen too much to all the hype regarding lack of range. /$.02
I think that the real problem lies in the fact that the software is switching between FCC and CE without the pilots' knowledge. It's clearly documented all over the interwebs. Once DJI gets that sorted, I think we'll all be on the same page.I'm just saying that built-in antennae is not a good design choice with respect to signal strength. I do not "listen to the hype", but if signal strength is not as good, I would not be surprised. That's why I will wait for more people to use it and share their findings. If there are any such issues we will most probably read about them somewhere.
In my opinion, it would make more sense to make the mini 3 compatibles with the RC Pro of the Mavic 3. There is an option to buy the Mini 3 without a controller and I initially thought that was the case until I looked up the compatibility with Mavic 3 RC Pro. Though there is a remark that more compatible devices may come at a future date and check back.
I can confirm that DJI RC now works with Mavic 3. I upgraded the firmware and app on the controller, which in turn updated my Mavic 3. Interestingly, the message about binding the drone popped out (see screenshot attached), allowing me to fly five times only with Mavic 3 unless I agree to bind it permanently. I am yet to try whether going back to Mini 3 would require unbinding with the larger drone.
Yes, switching between drones on the RC Pro and the DJI RC requires the binding and unbinding from the same pop up screen each time, or you can connect up to 5 times without changing the binding, which is supposed to relate to the DJI Care "Flyaway" coverage.I can confirm that DJI RC now works with Mavic 3. I upgraded the firmware and app on the controller, which in turn updated my Mavic 3. Interestingly, the message about binding the drone popped out (see screenshot attached), allowing me to fly five times only with Mavic 3 unless I agree to bind it permanently. I am yet to try whether going back to Mini 3 would require unbinding with the larger drone.
When used with drones that support O3+ transmission, like DJI Mavic 3, [1] DJI RC can provide low-latency HD 1080p/60fps live feeds with a max transmission range of 15 km [2] for smoother control and safer flight.No. I don't want internal antenna, less brightness, no O3+, and no other android apps.
What I really want to be able to use is the RC plus with the mavic.
You misunderstand.When used with drones that support O3+ transmission, like DJI Mavic 3, [1] DJI RC can provide low-latency HD 1080p/60fps live feeds with a max transmission range of 15 km [2] for smoother control and safer flight.
