- Joined
- Feb 19, 2017
- Messages
- 660
- Reactions
- 302
- Age
- 72
It comes into camera view a lot, especially when it's windy, or when you need to fly a little faster. It has ruined a lot of my videos. I'm open to suggestions for one that actually works.
I normally fly with the cover off, better pictures and no prop reflection.Just out of intrest. My first post on here btw. Hello all. Do most people fly with the gimble cover on or off? I am new to the drone world and have been taking it off when flying/recording. The one time i had it on i could see hair line type shadows/glare on the footage which im guessing is what the gadget in the OP is meant for. Although looking at the reviews on here not worth it.
Thanks
Jk
Apparently I'm doing something wrong I've never had a problem with the sunshade. At high speeds I see the props but not to shade. But I've never ran without the shade. I'll have to try it without the shade and see if it's really the props.I normally fly with the cover off, better pictures and no prop reflection.
It does work ---- I had the same problems the op had when I was in Sports Mode going full speed forward I would see about an 1/8" on the top of my screen ------ I trimmed it down and it's fine now .
I think this shade was not designed to shade the sun from the Mavic camera from the front (flying into the sun) They should specify this.
It does shade the camera from the sun approx. at 1 o'clock to 5 o'clock from the sides ---- This also I feel they should specify
Just my 2 cents on this Shades problems
Cheer's
You do have a point about reduction of air flow into the air intake even though it is minimum , I would not use it on hot days just to be safe .It also helps with prop shadow which I've gotten a couple of times while flying with the sun overhead. It's made for taking video in tripod mode or slower speed. Personally if I'm going to be flying in a more spirited style I don't want anything that might cause any reduction in flow into the air intake so I wouldn't use it in that situation anyway.
