downgrade asst2 1.2.0
hewo
Honolulu
where can u dwnld asst2 ver1.2.0 ?
ver1.2.4 says minimal djigo4 ver4.3.0
i will examine 4.2.12 djigo4 perform
it violates asst2v1.2.4 mandate use djigo4 minimal v4.3.0
thus need for prior asst2 ver1.2.0 dissolving mandate minimal djigo4v4.3.0
Assistant 2 is unaware of the version of DJI Go 4 you are using. It doesn't matter. Unless you use the simulator in Assistant 2 I don't even see a reason to hook up your device when using assistant 2. Even then it doesn't do much
Ok, so IGNORE claimed warn "...before firmware flashing make certain youve updated djigo4 to minimum version 4.3.0
Djigo4v4.3.14
aircraft 01.00.0200
rc. 01.00.0000
Target desired version 4.2.12 djigo4 apk
Target desired version 1.2.0 dji assistant 2 pc
Djigo4v4.3.14
aircraft 01.00.0200
rc. 01.00.0000
So you you aren’t looking to upgrade your firmware on the ac or the remote. You just want to make sure that DJI Go 4 4.2.12 will work with the current version on the firmware you have installed correct?
What do you need Assistant 2 1.2.0 for then? You could just try version 4.2.12 on your device and if it doesn’t work with your ac then it’s easy to install 4.3.0 instead. maybe I’m not understanding what you are trying to do.
Desire staying away from latest firmware. rc firmware hasnt evolved much. close radius disconnect occurs using latest fw. support replaced craft and rc but disconnect close radius persists indicating possibly another cause.
The midget phone rc cable is loose at rc connect, no warns, no observed discrepancy.
Disconnect is by interference. Warns of strong aircraft interference plus latency lost screen black and white plus antenna signsl weal orient them favorably.
I desire downgrading aircraft unto fw debut date 2018 january 23rd
Yesterday i cleared ver1.2.4 asst2 warns of "incompatble fw modules" by triplicate fw writes unto three separate batteries, fw01.00.0200 writes battery too. ignored geofence fw write nags of asst2.
Backwards flashing is desired for aircraft now at fw01.00.0200 and that is why asst2v1.2.0 is in need. Now with asst2v1.2.4 the earliest is 0200 but with earlier asst2v earlier aircraft fw will reveal?
Btw, the signal lost close radius problem is consistent. It does not matter which community park flown. Suspicion is military umbrella jamming altho people would be complaining. I dont see aircraft flying receiving strong aircraft interferences
What country are you in?
jhgfdhjrye
