So I got this error message today while flying my MPP. I’ve only had this for about two weeks so I’m pretty new at it, is this something I recalibrate through the app or do I go online? It still flew and landed just fine. Thanks
Instructions to calibrate the Mavic Pro vision sensor using DJI Assistant 2 along with tips to fix the vision system error on the Mavic Vision Positioning System
www.dronezon.com
the you tubes all seem much of a muchness and this is the one I watched
I did an M2P last night on a laptop and, due I think to using the laptop, it was a bit of a pain in the derrier.
If you have a seperate and large screen it's probably a lot easier.
I found the keybpoard kept getting in the way of the drone's legs and ended up with the laptop on a lap etc. tilt stand with the keyboard at about 45 deg to the horizontal and the screen leaning slightly backwards so that it was facing partially upwards. That I had to be more or less directly infront of the screen myself (meaning behind the drone) in order to see the screen didn't help matters.
A 'proper' screen again would probably make it easier.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
