Drone Drowned!
Thanks all for your replies! It took a bit for the sting to go away and indeed I did order a replacement. Hopefully i will be back in the air (a bit smarter) soon!
It was my understanding that the logs on the phone will take you to exactly where it went down.
Not quite exactly! Plus 15' down, plus murky water, plus salt water damage.... especially after 8 days submerged!!! I just swallowed my pride and take it as a lesson learned!
I did look for the log but I think the flight was so short it never got a log started.
Not likely. As soon as you power the drone on, it starts the log. No flight is even necessary.
Good luck retrieving it.
Yup Toni you are correct! Had to manually go in and find it but I did and have a last known gps coordinate for it. Not certain what I will do with it. BTW will a magnet pick one of these up? Might try fishing for it for fun!
Reactions: Tony McDrone
If you had a strong enough rare earth magnet you might pick it up by a motor but I checked mine and can't find anything magnetic except the motor.
How deep is the water?
If you have any current there in the water it's probably moved quite a distance. These things are so light it wouldn't take much to move it around.
Reactions: Nodak7
M5P
