Drone Help for Project
JohnCenaDrone
Hi all,
For my project I am trying to get an accurate positioning of a Mavic PRO drone while in flight, I understand you can obtain the flight log with DJI assistant. Is there a way to obtain the flight log without this software?
Also, will the altitude from the Mavik flight data be measured with GPS, Barometer or the VPS system (under 0.5m) and when do they use each?
Thank you!
any responses are greatly appreciated.
Hi all,
Thank you!
You need the software. The Mavic uses GPS, Barometer and IMU all the time; it uses VPS when it is .3 - 13m AGL.
BausInGV
