Thanks for the reply.There is a max airspeed the aircraft will use for RTH, if the wind is faster than that then it can't come back.
Yeah, that’s true, but you know how it goes... sometimes the best shots happen right when the winds are stormy.Yeah, but then there can be an even faster gust that takes it farther away.
When wind's that strong you probably don't want to be flying/stay lower to avoid the stronger winds higher up.
