Drone Newbie Here!
Welcome to the forum! :)
New to drones and after extensive research, pulled the trigger on a Mavic Air 2
Here are some things to help you get started with your Mavic Air 2:
  • The current Mavic Air 2 manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mavic Air 2 downloads page.
  • Check out this getting started guide for some tips not found in the Mavic Air 2 manual.
  • This video covers all the basics of the Mavic Air 2.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching .Thumbswayup
Hi SteveOMA2 Welcome to Mavic Pilots.
New flyer advice,
Wide open space.
Slow & easy
Power-lines & trees are evil.
Don't expect RTH (Return To Home) to save you especially if you are under trees.
Don't forget to read the manual ;)
Download Air 2 manual HERE
Most of all have FUN
Thanks for the advice. Way ahead of you. I lurked around here and picked up these tips before I every got my Air2! This is a great forum for advice and info. Thanks!
WELCOME to the forum :)
jimcsnr
