Drone usage time scale
  • Thread starter Thread starter Deleted member 133794
  • Start date Start date
D
Guest
How do i find the information about my MA2 usage...IE Age, number of flights flown, time in sky.
I can't find anything on the FLY APP under the About Tag.
Under profile it's only showing last 3 flights not total flights
Use Airdata and it will upload all your flights ..
Tried that but it only shows last few flights. I'll try Airdata next.
Mine shows every flight in all of the drones I have had .... weird..you not got it filtered maybe?
Reactions: hiflyer201
AirData won't help if this a USED drone your buying. It would need to already be logging that data to the cloud to observe it.
The FlyApp should have most / all flights done in it as said above. Unless the person "selling" the drone hacked it to remove flights so it would look barely used. Do not know whether this is a sell / buy; but seems so with the question, but lacking in details!
What does the "seller" say is the flight record?
That only works if the Fly app is the only app ever used to fly the drone. If Litchi, Dronelink or another flight app has been used then those flights aren’t logged in the fly app.
Chris
Reactions: ckoerner
Thinking of selling so wanted to make sure i had all relevant info first.
After some head scratching i've now recovered it all from the cloud,
just took a while to download.
Thanks for your advice ??
Chris
Thank you for your help ??
Reactions: Chrislaf
jenniferwilson
