Drone Valley--Reputable?
harmonix234
planning on ordering from drone valley.
want to order some items but the site is simple and im worried of the safety of the purchase.
this site ok to order from?
Depends what your buying... If its a big order than NO I would not purchase from DV. However If its a 12 inch apple wire than Maybe... . I watched some of his You Tube Vids and his Knowledge is highly questionable , he educates himself by watching other You Tube videos. It's obvious that DV is new to the hobby. Why risk it.?
Reactions: avanti1963
Depends what your buying... If its a big order than NO I would not purchase from DV. However If its a 12 inch apple wire than Maybe... . I watched some of his You Tube Vids and his Knowledge is highly questionable .Why risk it.?
I ordered from them the lightning cable, no problem
landing pads and range amplifier.
can you recommend another site i can use to grab these items?
Range amplifiers can be purchased on Amazon. I have several. But they are only good if your pointing at your drone.. Don't turn away at long distance. Signal drops very fast. Many different styles of landing pads. We use a large welcome mat that says "Yes My Dobermans Eat Humans" .
sorry i should have made it more clear.. the leg extenders and the little numbs that go under the drone to elevate it.
I've ordered from DV in the past and they're legit. BTW...he sells a ton of the leg extenders. They're usually not in stock so grab them while you can.
I just ordered the leg extenders and mobile charger from DV too. The leg extenders are great and much smaller than I anticipated. No issues at all with order and took about 3 days to receive.
By the way, I really enjoy his videos and think he shares good practical advice, especially if you're new to this hobby.
DV is legit I ordered the ground clearance kit, iPad mini cable and propeller guards and everything arrived fine. Great communication during the ordering process.
twixer_bear
