DroneDeploy error message
Gagey52
Northern Territory AUS
Has anyone come across an error message in DroneDeploy about damping (Error 231)? I cant find a reference to it anywhere. Assistance appreciated.
Regards
Im no expert on this but check you Curve radius on your Way Points to see if they match the tolerance levels.
Phantomrain.org
Gear to fly in the Rain.
tengo un mavic pro y el dronedeploy me arroja "plan upload failed: the damping check is failed (231)" cuando quiero ejecutar el vuelo programado.
Alguien sabe que puede ser?
Here's the place to ask that:
Same as here Meta4 no response unless I want to pay for full membership
So I found on the PhantomPilots a thread from 2015 that’s it a DJI controller issue. Nothing to do with DD.
Brett_GLP Drone Services
