ESC STATUS error
juan pablo
Hi, the mavic Can't take off. The motors don't start at all. I restarted many times, calibrated compass, Imu, camera, link remote control etc.
But the screen still shows "ESC status error" when I check the error i can see this "2No.Motor error"
Anyone knows which is the 2 motor? If I replace the motor the error disappears? Thanks!
The ESC is a seperate piece of electronics which controls the speed of the motor. So it could be the ESC or the motor that's failing. Sounds like a warranty job!
Reactions: dewster
When did you start seeing the "ESC status error" error?
I'm not sure.
Check the cables between the forward arms.
Open them halfway and start the mavic. Might be an issue with those cables
Those ESCs are embedded on a circuit board. You'll have to send it in for repair.
I got a brand new mavic air with the same problem, i activate update all firmware and the message cant take off and a warning says esc status error. Never have fly the drone just out of the box.
BigPapa98
