FAA Notice I received Today
Edward Knight
Jacksonville Fl
August 30: Stay informed about Hurricane Dorian’s impact on aviation​
Hurricane Dorian Safety Alert for Drone Pilots!
The Federal Aviation Administration (FAA) is monitoring Hurricane Dorian closely and preparing FAA facilities and equipment along the southeast coast of Florida to withstand potential damage so flights can quickly resume after the storm passes. Restoring air carrier service is critical to support disaster relief efforts.
Drone users should check NOTAMs and TFRs and avoid flying in areas where drones are prohibited
Drone pilots must comply with FAA rules and should:
  1. Avoid flying in the area unless conducting an active disaster response or recovery mission.
  2. Be aware that the FAA might issue a TFR in the affected area. Be sure to check for active TFRs if you plan to fly.
  3. Remember that you cannot fly inside a TFR without FAA approval.
Drone emergency operations and response:
  • During a natural disaster, do not fly your drone in or around emergency response efforts, unless you have special authorization to do so. There are low flying aircraft as part of the storm response — mostly in low visibility areas. If you are flying, emergency response operations cannot.
  • You may be able to get expedited approval to operate in the TFR through the FAA’s Special Governmental Interest(SGI) process as outlined in FAA Order JO 7200.23A. Submit an Emergency Operation Request Form with your existing Remote Pilot Certificate or existing Certification of Authorization (COA) — and send to the FAA's System Operations Support Center (SOSC) at [email protected].
Don’t Be That Guy!
Be aware that significant penalties that may exceed $20,000 if drone operators interfere with emergency response operations. Flying a drone without authorization in or near the disaster area may violate federal, state, or local laws and ordinances, even if a TFR is not in place. Allow first responders to save lives and property without interference.
If you are not certified as a remote pilot or do not already hold a COA, you cannot fly.
Follow the FAA on social media for the latest aviation news!
Don’t Be That Guy!
Thanx for sharing this information...be smart, fly SAFE!
its great that they are doing this,in the UK its the CAA that issue alerts on such topics knowledge is power and if it saves you from ending up in trouble then that is a good thing ,and you never know it might even save a life
Interesting!
Don’t Be That Guy!
I believe you can subscribe without having registered a drone. Subscribing to notices is just an option presented to you.
in the UK you can register for the CAA app skywise without the need to own a drone
tflys78
