FAA Numbers
Gonzo66
Can I use the same FAA numbers for multiple drones or does each drone need its own number?
Yes if you are a hobbyist that # is assigned to you. Put it on all
your drones over 250 grams.
Reactions: Thomas B
If registered under HOBBY and only being flown for HOBBY then all aircraft can use the same #.
Commercial is specific to each aircraft.
Wesleydjimavic2pro
