Just thought I'd mention this in case someone else has the same issue.
After I did the last update on my Mavic 3 I started getting the error 'Failed to load dynamic safety data'. Clicking on 'Check for updates' confirmed that 'firmware is up to date'.
I normally do the updates inside where it is warm. However I found that going outside where the M3 could get GPS lock and then checking for updates again allowed it to find another update which it downloaded and that solved the problem.
Just means I have to check for updates at -4c rather than inside!
