That won't matter since the home point is set by the aircraft -- and it uses its internal GPS receiver to find its location.So a monitor or different device makes it faster??
I am on vacation in Montana and trying to film rafters coming down a wild river in a canyon! I can barely get my Mavic Air into the air and get a home point as they are coming down the river, and barely get 8-9 satellites and by that time, I miss the shot every time. I am really trying very hard to time the rafting schedule so I know when they are coming down the river. Any hints or help?Clear line of sight to the satellite system that it’s looking for is the key.
You just need to give it the time it needs. I believe 10 sats is a good minimum to watch for before you send it off.
The IMU has nothing to do with GPS and makes no difference at all.on the Phantom 3s the IMU cali made a good difference.
Cloud cover makes no difference to GPS.Cloud cover will also slow the process a bit.
There are always myths to shoot down.
Your drone's GPS acquisition time will vary.
If you have a clear, unobstructed skyview and have flown recently in the same area, the GPS will know where the sats are already and get a fast lock. (hot start).
If it's been a longer time since the drone was used, it will take longer (cold start).
Time to first fix - Wikipedia
en.wikipedia.org
If you want to have a fast startup, you should start the drone and get a good fix and shut down.
Then when you want to fly again soon after, it's going to get GPS faster.
So here4 is my question
If I get my GPS fix, **** down, and then change out the battery to a full battery, will this work?
Thanks- that is the most helpful piece of news I have had rom this thread. I am going down there today and I already know the time frame for the rafters coming through, so I will set up, start up the drone, get a compass calibration and fly over my landing mat at 33 feet for 30 seconds, then, land it, and change out the battery (is that ok???), and wait for the rafts to come through.
With respect to clouds, the only way you can get cloud movement in a drone shot is setting individual intervals as JPEG's and 2 second intervals, then processing it as a timelapse.
Still looking for an answer to this question....If I start up the drone, get the home point and GPS fix and then land it and change out the battery, will all that data "hold?"If you are in an area with heavy tree cover or such, you could just take off straight up above the cover and wait for the home point notification. I do this a lot flying up north in the woods and have had good success with fast GPS lock once in the clear.
No. When the drone is powered down after landing or the battery removed the home point will automatically reset. (guess the latter is the same scenario). This can’t be changed.Still looking for an answer to this question....If I start up the drone, get the home point and GPS fix and then land it and change out the battery, will all that data "hold?"
