FCPX export-bad results, need your help
Piranha
Guys, I just switched to FCPX and found that I do something wrong with export of final movie
I edited my 2.7K footage add some color correction and than share master file in 2.7k, result is disappointing totally :(
picture is unsharp, all details washed out, what I'm doing wrong
Go to Window -> Project Properties (or ⌘J) and set your parameters.
Don't forget that FCPX takes the first imported file as a benchmark for the rest (when you use a low-res intro or picture). But you can adjust that with the above mentioned setting
If it still doesn't work, send me a private message
Reactions: Piranha
Irish_Sinner83
