Field Monitor Stand/Tripod
Desert Drone Works
Fancy Title Here
Tucson, Arizona
Site
www.desertdroneworks.com
Hi all. Looking for some real life examples of what some of you use for a field monitor setup. I'm trying to balance convenience, cost, and stability. What I'm trying to accomplish is using something like the Feelworld LUT11 battery powered monitor connected to my RC Pro/M3P via HDMI. What I'm struggling with is finding a tripod (or other configuration I haven't seen yet) that is stable and not $250+. Anyone out there with the needle in a haystack solution?
I'm aware of the LifThor for RC Pro, but am not wanting to mount something directly to the RC and adding weight. I'm wanting this weight to be strictly on the tripod/mount.
Thank you.
A fellow member @Donnie Frank does a lot of Field Work so he may be using something that would work for you. Hopefully he'll post and let us know.
Well, in case anyone does a search and comes across this: I went ahead and purchased the Feelworld LUT11 field monitor and am using a basic tripod for now. I have a gig tomorrow so am planning on testing it then. As of right now, I'm very pleased with the setup. We'll see how annoying it is after an hour or two tomorrow.
Should work fine... add additional weight to the tripod if needed.
Reactions: Desert Drone Works
Jason - how did you export that video to the monitor? I get the full HUD when I connect the HDMI Cable.
Wesleydjimavic2pro
