I've got an Arc V on the back of the battery cover of one of my Mini-2s, and I've never seen a problem that I could attribute to interference from it.Quick question, Does the Firehouse ARC V cause any type of interference with the MA2? gonna be purchasing one in the next day or so and don't want it if its gonna cause issues like the lumcube,
Do you have any particular reason for red in the front and green in the rear and not vice-versa?View attachment 146367
FOUR Arc V's... No issues. At night over water I've flown out as far as 10,000 ft, still being able to see the drone with no interference at all. Sometimes instead of red/green mounted on the arms I'll put a red in front and a green in the rear for orientation. Top and bottom are clear strobes.
I have found no issues attaching strobes top, bottom, front, rear as long as sensors are not blocked. During the day I put one or two in front ((usually red) one in the back (green) one white on the bottom. At night I add a white on top.May be answered elsewhere, but do these (or similar) strobes interfere with the anti collision sensors? Thinking of getting one for the top of my Air 2s, to put between the sensors on top. Or is it recommended to put on top of batteries as mentioned above?
Where did you pick up those nifty mounting brackets?I have the exact same setup on my Air 2S and Mavic 3 without issues. \
They must be out of the body mount. Can only find the arms.Firehouse have it.,
Drone Accessories/ Mounts
Drone strobe lights DJI Drones anti collision lights drone spotlights uas strobe drones dji m30 m300 mavic air mavic mini autel roboticswww.firehousetechnology.com
