Firmware
shawgod
Onalaska, WI, USA
I have a Mini 2 that is giving me the Error “Aircraft module firmware versions do not match. Incompatible firmware version. Go to Profile > settings to update firmware. Code 30224. When I do exactly as it says, there is no updates for the drone or controller. Everything else seems to be working just fine except this. I have tried to update firmware in the about section as well and it doesn’t find an update there as well. The fly safe data did update right away tonight when I connected the drone.
Have you checked for a battery firmware update? DJI Intelligent batteries sometimes need firmware updates and if you have more than one battery then they need updating too.
Reactions: buddb55
Interesting post
How do you know f your batteries require firmware updates and if they do how do you update that firmware ?
The batteries don't require any updates. I tried a couple batteries and both didn't require anything. This is a brand new drone, never flown. The only thing done with it was I have updated the drone to the latest firmware, the batteries to the latest firmware, and the remote to the latest firmware and charged the batteries. So I don't know what is going on. I know when I get to the place I plan on flying I need to calibrate the compass. But that shouldn't have anything to do with this.
jeremyscott
