First crash. Minor scratches on camera lens.
Abuskeletor
So, RTH caught me off guard while I was focused on the drone and not the app, and my Mavic Air flew up into a tree, then stopped and fell to the ground. I cleaned it up, started it up and it hovered and was stable. I was on my last battery, so I haven’t done much else to test it. Two things: 1. I have a couple scratches on the lens. How bad does that look to someone with more experience than I? 2. It said something about switching to secondary IMU after the crash. Do I need to take action on that?
My batteries are recharging now so I can test it more thoroughly.
I would definitely do an IMU calibration.
Do scratches show up in pictures? If not, leave it be.
I got the batteries charged and played with it a bit. Compass and IMU are calibrated and the app shows all systems green. Flys steady, gimbal works right. Shot some pics in the house and didn’t notice any distortion or artifacts. I think I’m in the clear. Thing took a 30’ drop after the RTH took it into the branches. I’m not impressed with RTH, but I am impressed by the durability of this thing.
dumb robots just do what they are programed to do
If it is scratched, bear in mind it’s not actually a lens but a clear cover. You could buy a set of ND filters that would screw on instead and also give you picture benefits.
Reactions: cyzerman
When you detach the existing ring around the thread, there is no clear cover, it's just a plastic ring. These scratches are on the lens themselves. Adding a ND filter will not help you in this instance.
You sure the lens is scratched? Not on a mavic but I had a lens that was thought to be scratched,,, turned out to be some kind of buger.
Now I wonder if someone makes a screen protector for this thing!
Yeah, I tried to clean the lens up, and the marks in the picture are definitely scratches. I took some test shots and didn’t see any issues.
You’re absolutely right, apologies. A shame really, a clear lens attached to the ring would have been a good design choice to help with exactly this scenario. Leaving an ND filter on permanently would seem like a great idea.
Reactions: Abuskeletor
PolarPro makes a UV filter -- no ND correction -- that can be left on all the time if you don't want to use ND.
Reactions: Elton Hammonds
I have the PolarPro UV filter, and leave it on all the time, specifically for the protection. I’ve been using UV filters as lense (and filter thread) protectors for decades. NOTE: make sure the filter is no higher than the original ring, to be sure that you can install the gimbal protector correctly, on top of the filter; PolarPro fits, but some don’t - check the spec before buying.
JackyZ
