First Flight Questions
floridadroneman
Jacksonville Florida
Owned a Phantom a few years back, just got a Mini Mavic today and had a few flights. Some issues that kept popping up;
-Period low battery warnings even though the pack was fully charged and the display showed ~80-90% charge left. This created a couple of return to homes and once I disabled that, I continued to hover with no true battery loss or shut down of drone.
-Payload warnings (I currently have the blade protectors on). Should I disable this mode while still using the protectors so I can fly a little higher?
post your flight data
it is not possible to disable the payload mode with the prop guards fitted, it switches to that mode automatically when you lift off
bsf
