First update in 6 months and now problems
pilot1
I just updated the software for my Mavic in 6 months and now it will not climb above 90 ft even though I have the max altitude set for 500M. Also my DJI A
ssistant 2 will not recognize Mavic when I plug it in via USB to the computer.
Please help!!!
are you in beginner mode,updates will reset your particulars
When connecting to the PC have you turned the Mavic on
Also have u updated app? U may have to resign into the app...about 6 months ago they implemented that basically if u dont sign into app u are restricted in height and distance. I would just delete app and reinstall
Thank you-I did update the app and it cured the altitude issue. I am still unable to get DJI Assistant 2 to recognize the Mavic no matter what sequence of connection I use. I have tried different cable. Running Windows 10 BTW, it will not recognize the remote controller either.
I heard something about windows 10 not letting the dji drivers install ..(firewall)?. you have to try to figure that out and make sure they install otherwise try a different computer
Same issue here today. Toggling beginner mode did nothing. Capped at 30m max alt despite rth & max alt set, beginner mode off. Only fix I found was to restart the mav. "Cleared" the issue both times. Very annoying tho.
+1 You probably need to turn off the Windows 10 driver signature enforcement, so the relevant drivers can load
The easiest process is option 2 in the following how-to
https://www.howtogeek.com/167723 ... l-unsigned-drivers/
Note, if you restart the PC you will have to do the process again as the change is not permanent
mjauuu
