I’m back. Studying for the 107 now and have a few
Mavic 3’s and a
Mini 3 Pro
mavicpilots.com
Since you have not been active for some time, there are a couple of Legal Things you may need to do…
Until you pass your Part 107 Exam, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Some of your Drones weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register those Drones, the
Mini 3 maybe not, with the light battery..
When I first started flying I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone.faa.gov
Since you are considering acquiring your Part 107 License, here is a link to get you going… I took this course and I easily passed the Exam with a 100%...
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the links to all of the downloads offered by DJI for the
Mavic 3 and the
Mini 3 Pro, including the User Manuals
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Learn and download DJI
Mavic 3 related apps, software, and manuals at the DJI Download Center
www.dji.com
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
