Flight speed restriction on the Mini 2
frcaloy
Manila Philippines
I experienced flight speed reductions in the Mini 2 on occasions. I couldn't explain the flight speed restrictions at first but now, the mystery is solved. DJI restricts the Mini 2's speed when the camera is pointed downwards.
I was afraid of flying the Mini 2 thinking that it might not make it home due to the slowed down speed whose cause was unknown.
Now, mystery solved.
Thank you for sharing your insights and discovery.
It's a known problem, I thought it had been fixed, if you have it you might want to update stuff as it can / could result in blown-away drones.
Alternately set the fn button to swap between camera horizontal and camera fully down, it gives a quick pitch-change of the camera and seconds might be vital.
Reactions: LoudThunder
The update by Dragon7 youtube says the restriction was removed. Dated 1 year ago. I have no idea myself.
Restriction is still there. There is a thread where slup made a chart of recent flight.
Reactions: BOT and LoudThunder
I discovered this issue back in January of 2021, my mini 2 did a little walkabout and I barely got it down. Here's a couple threads about it...
jameswgm
