- Joined
- Oct 16, 2017
- Messages
- 5
- Reactions
- 1
- Age
- 52
I would say maybe 4m above the waves, the largest waves about 1.5m but even at the shoreline the waves rolling up the beach were making the mav move backwards more than the actual waves. Only small waves being realistic but Big when your mav Is close lol. Looks awesome as the waves are cresting and rolling, just a bit unnerving as the mav is unsettled and the video looks naf with all the movement, great otherwise in tripod mode.
Thanks KDogI've flown around this height with slightly larger waves, with all sensors on and had no issues. If you're flying in GPS mode, then that should be the primary means of location control and shouldn't be using the bottom cameras to adjust position.
My first thought is whether you put it up before it had GPS lock and you were flying in atti mode? Second thought is whether it was actually wind and the wave movement was a coincidence. If you've isolated these as issues, then I'd switch off downward sensors and see if the issue persists (remember to land with much more than when flying with sensors on).
