Flying when it's overcast
It says "
(1) 500 feet below the cloud; and (2) 2,000 feet horizontally from the cloud.
If you are under a cloud that is 1000 feet above and covers your state it's hard to get 2000 feet away from the cloud horizontally. I just ignore the rule and fly :).
Let me help clear this up.
If there is a cloud directly above the drone, then the drone must have 500 ft of vertical clearance. The horizontal limit does not apply when flying 500 ft below the cloud, unless you are dealing with two layers of clouds.
If there is a cloud to the side of the drone, then the drone must have 2,000 ft of horizontal clearance. The vertical limit for clouds does not apply when the drone is clear of clouds by 2,000 ft. To say that another way, the drone does not have to be below a cloud that's half a mile away.
A third way to think of this:
Draw a rectangle around the cloud from your perspective. The rectangle must extend 500 ft below the bottom and 2000ft out from the sides. The drone is not allowed anywhere in that rectangle.
Reactions: MS Coast and AZDave
It says "
Hmmm... The presence of both "below" and "horizontally" leads me to naturally interpret the horizontal limitation to only apply when you're less than 500ft below.
Yes, it would be clearer if it said, "if less than 500ft altitude below the altitude of the cloud bottom, you must be a minimum of 2000ft horizontally from the cloud".
Not to pick nits but just to be clear... In my interpretation, the 2000ft limitation only applies if you have less than 500ft vertical clearance. If the cloud is at 2000' AGL you can completely ignore it... you don't have to get 2000' away as son as you come out from under it's shadow.
Sir, best is to fly within VLOS (Visual Line of Sight)... So no worries and Enjoy flying throughout the year...
I fly in Seattle, and best practices are to check the weather on the LAANC flight app. Often during overcast, the visibility can still be up to 5 miles with clouds well over 500', which gives some room to fly. I rarely need to take it up to 400'. And it's not clear where exactly that 500' report is. Is it at the blue dot, or generated from a local weather service averaging for the entire region? The Puget Sound area is huge. Sometimes it will look like the clouds are less that 100', especially over lakes here, but this is often fog, because the cloud report is much higher. VLOS is the key here because even on foggy days, it's in isolated locations and the visibility may still report on the app as up to 10 miles. The Pacific Northwest has so many different weather events happening, even within Seattle proper, the rain and overcast can vary. I've flown in light snow and rain here, being careful never to be over people or property, and using only the minis. I've found that the props will throw light precipitation away from the tiny motors, and I keep my flights very focused and short. Once I have the photo, I'm back down immediately, often in under 3-5 minutes. I've been accident-free in the city since 2019, when I got my 107. Otherwise, I've had only a brush with branches under a tree canopy outside the city. I don't recommend trying to fly in the woods. Even during severe clear, what's critical to safety in my opinion is what is heard, not just seen. I've had one very close call (in uncontrolled air space) with a low flying helicopter coming off the Sound and over a bluff where I was flying legally. The sound tipped me off way before I saw the copter at I estimate below 300'. It climbed as it went past me. I was able to drop down to below neighborhood tree-line before I made a visual, which was in maybe 5 seconds. It came in very fast and loud. A cautionary tale: I strongly believe in being especially vigilant when flying near noisy traffic or construction; and to never have anything in or over your ears while flying, especially in urban areas. Full stop. fyi
For a more professional preflight briefing, include this website as one of your sources of information, and zoom in to your region:
This plots the official METAR observations on a map in real time, and it will be very clear where the reports came from.
Reactions: journo
This is cool; I'll need to decode some...thank you.
Reactions: robc007
Very cool. Thank you! Btw, the app is off by 500' (overcast today); this shows ceiling is actually 1000'+ over Seattle/King County, not 499'/98% cover.
That's the "Ceiling & Visiblity" page, a product I'm not very fond of either. The "Observations" page and the "METAR/TAF data" page are my two favorites. Sometimes I visit the "Winds" page because the text briefing provided with my flight plan has only limited enroute information.
Reactions: journo
Just for the grins of it I asked Grok, an AI:
There is a FAA part 107 rule that states: (1) 500 feet below the cloud; and (2) 2,000 feet horizontally from the cloud.
How is the word “and” interpreted? If there is a cloud 20000 ft directly above you are you violating the 2000 ft horizontally portion of the rule?
Let’s break down the FAA Part 107 rule you’re referring to and how the word “and” functions here. The specific regulation, under 14 CFR § 107.51(c), governs visual line-of-sight operations for small unmanned aircraft systems (drones). It states that the drone must remain at least (1) 500 feet below the base of any cloud and (2) 2,000 feet horizontally from any cloud. This applies when you’re operating under visual meteorological conditions and need to maintain visibility and avoid cloud-related hazards.
The word “and” in this context is a conjunction that connects two distinct requirements—both must be satisfied simultaneously for you to comply with the rule. It’s not an “either/or” situation; it’s a dual condition. The 500-feet-below rule addresses vertical separation, ensuring the drone stays well under cloud bases to avoid turbulence or sudden weather shifts. The 2,000-feet-horizontal rule addresses lateral separation, keeping the drone clear of clouds you might see off to your side, again for safety and visibility.
Now, to your scenario: If there’s a cloud 20,000 feet directly above you, let’s think it through. The first condition—500 feet below the cloud—isn’t an issue. At 20,000 feet above ground level (AGL), you’re far more than 500 feet below it, assuming you’re flying near the surface (Part 107 limits you to 400 feet AGL unless near a structure). So, that part’s fine.
The second condition—2,000 feet horizontally from the cloud—is where your question gets interesting. If the cloud is directly above you, its horizontal distance from your position (or your drone’s position) is effectively zero. Picture it: a cloud centered overhead means its edge hasn’t even started 2,000 feet away from you in any horizontal direction. By the plain wording of the rule, you’d be violating the 2,000-feet-horizontal requirement because you’re not maintaining that lateral buffer.
But here’s where real-world application comes in. Clouds aren’t perfect points—they have width and depth. If it’s a small, puffy cumulus cloud 20,000 feet up, its edges might still be thousands of feet away horizontally, depending on its size. High-altitude clouds like cirrus, often at 20,000 feet or more, are thin and wispy, spreading out over miles. The FAA’s intent isn’t to nitpick a cloud directly overhead at that height—it’s about practical safety. Their focus is on clouds you could realistically approach or that could obscure your drone or line of sight. A cloud 20,000 feet up isn’t likely to interfere with a drone buzzing around at 400 feet max, unless it’s part of a weather system dropping lower clouds nearby.
So, technically, if you interpret “2,000 feet horizontally” strictly and the cloud’s base is right above you, you’re not compliant. But practically, the FAA isn’t hunting for that gotcha. They’d care more if you’re near clouds at lower altitudes—say, a 1,000-foot ceiling—where your drone could drift too close vertically or horizontally. If that 20,000-foot cloud is part of a storm system with lower clouds within a couple thousand feet of your drone, that’s when you’re in trouble.
Has the FAA ever charged anybody with an infringement of this rule?
The FAA has indeed taken enforcement actions for violations of Part 107 rules, including the cloud distance requirements under 14 CFR § 107.51(c), though specific cases tied solely to the 500-feet-below or 2,000-feet-horizontally cloud rule are tricky to pin down in public records. The agency doesn’t publish a detailed, case-by-case list of every infringement, but we can piece together some insight from what’s out there.
Enforcement data shows the FAA has pursued hundreds of cases against drone operators since Part 107 took effect in 2016. By mid-2023, they’d issued over 1,200 enforcement actions, ranging from warning letters to hefty fines—some as high as $182,000 in a single case against a Philadelphia operator in 2021 for reckless flying. Most publicized cases involve blatant violations like flying over people, operating near airports without clearance, or ignoring visual line-of-sight rules. Cloud distance violations, though, tend to fly under the radar (pun intended) unless they’re part of a broader screw-up.
Take the 2020 Philadelphia drone crash during a fireworks display. The operator got slapped with a $6,000 fine for multiple violations, including flying over people and operating carelessly. Weather data from that night showed low clouds—around 1,000 feet AGL—which could’ve triggered the 500-feet-below rule if the drone climbed too high. The FAA didn’t single out the cloud distance in their notice, but it’s a fair bet it was in the mix of charges when conditions don’t align with regs.
Another hint comes from waiver trends. The FAA’s stingy with approving waivers for § 107.51(c)—fewer than 50 listed in their public database by late 2024—suggesting they take cloud proximity seriously. If they’re reluctant to bend the rule, they’re likely watching for breaches. Drone forums and pilot chatter also mention “close calls” with FAA inspectors during spot checks, especially in foggy or overcast conditions, though these rarely make headlines unless penalties stick.
No smoking-gun case screams “cloud distance alone got ‘em,” but the FAA’s track record shows they’ll pile on violations when weather’s a factor. In 2022, a Florida operator paid $10,000 for flying in restricted airspace during a storm—cloud clearance was almost certainly shot, even if the FAA spotlighted airspace over clouds. Penalties start light—$500 fines or warnings—but scale up fast for repeat offenders or high-risk ops.
So, has the FAA charged someone just for cozying up to clouds? Probably not in isolation—it’s usually bundled with other infractions. But they’ve got the tools and the will to enforce it, especially if you’re dumb enough to post your misty drone flight on X for them to see. Want me to hunt deeper into enforcement patterns or a specific incident?
And Grok got it all wrong.
The requirement is simple. There is a vertical cylindrical volume in the shape of the cloud perimeter and 2000ft away, radially, from the edge. That volume is cut by a horizontal plane 500ft below the cloud. You are to stay out of that volume.
A better way of stating it is, you are to stay at least 2000ft away horizontally if less than 500ft below the cloud botttom, when not under the cloud. You are to stay at least 500ft below the cloud when under it.
As a practical matter, nobody on the ground could precisely or effectively measure clearances below or to the side of something as amorphous and mobile as a cloud without some specialized instruments. And so, because everybody here knows that the intent of the law is to minimize risk of aerial collisions in low visibility environments, the simplest interpretation of its wording is: don't operate a drone near clouds and fog.
I often hear people say there's no such thing as a stupid question, but when a poster initiates a thread with a question that he or she already knows the answer to, that's really irritating.
There really are no ifs and whens. It's much simpler. You must be at least 500 feet from clouds above you and 2000 feet from clouds beside you.
I was saying the exact same thing, albeit in a much more confusing way 😁
I think where this gets unclear is, how do you fly under the cloud? What is "beside"?
Can you be 600ft below the bottom of the cloud and 1500ft to the side of it?
That's the "interesting", ambiguous area, and I think what people are questioning. You're not under the cloud... Do you need to be 200ft away horizontally?
I claim that the intent of the reg is the 2000ft horizontal distance only applies if you're vertical separation is less than 500ft.
More than that and you can fly straight on, under the cloud (say 1000ft, a very common situation here on the coast in Santa Cruz) and completely ignore it.
Take a cloud.
Add 500 feet to the bottom of it and 2000 feet to the side of it.
Now STAY OUT OF THAT AREA!
0x6e08715
