Focusing and avoiding blurred videos
Ian in London
United Kingdom
Well, some may know I lost a couple of clips a few months ago to poor focusing, so I've spent a bit of time looking at the various focus modes and the best setting that no one's talking about: Focus Peaking Threshold.
So hopefully everyone can pick up a few tips form this and avoid losing another video or picture to poor focus, and only finding out when they're back home looking on a big screen...
cheers,
Ian
Focus peaking is a useful tool.
One of the things I did when I first got the M2P was to just sit down outside and play with the focus, the various MF / AF modes (I haven't played with AFC yet and not sure I will). But almost right away (as soon as I saw the peaking feature was there), I turned it on.
It seems to have different setting names in Litchi vs. Go. I'm not sure yet if changing one affects the other.
Chris
Chris
I can see why Focus Peaking is defaulted to off as it's quite 'in your face' for the display, but it's so useful and really gives you a sense of 'yep, everything is in focus for me' whilst you're filming.
CHeers
Ian
Not to be a heretic, or a contrarian, or cause unnecessary debate, but I use AFC (auto-focus-continuous) exclusively and am constantly amazed at how well it works. No blurry videos, ever! I do understand the limitations like focus hunting and less than perfect focus under all conditions but it is one less thing to worry about when trying to get that great shot. It’s a great alternative for all of us casual videographers.
As it turns out, it's especially nice for changing focus scenarios, such as when you're starting off a shot by focusing on closer-in foreground objects, then want to change focus off in the distance (and yes, everything else) once you're above the close foreground.
You can't really see fine focus on a small video screen feed while moving, like you can though an optical viewfinder, so peaking gives you that indication at a glance.
Reactions: Ian in London
That's good to hear... As I mention, no one setting is a true all-round solution, so whatever works best is the best solution for you. And if you're mostly shooting subjects at some distance (ie no close ups) then there should be very little hunting and refocusing.... Cheers, Ian
Reactions: RadioFlyerMan
I am having major focus problems, changed to MF and set the white bar to second line from top as in a YouTube tutorial, was even worse. Thanks for this info, will check out focus peaking. I am a photographer and do not do blurred! Arghh
Unless you're planning on shooting things 3m and closer, you may as well just focus at infinity.
I was a JAFA :) for a year then moved to CHC for 3 years... Wish I had my drones back then........ :)
Focus Peaking is a real eye opener on a tiny screen
Cheers,
Ian
You can, but you can't assume the infinity symbol is infinity, so you still need to establish what is you're infinity setting.....
Cheers
Ian
Reactions: wendyc
Cheers,
Ian
Focus peaking at normal worked perfectly yesterday, as did my focus, so all good thanks
Phly858
