Fog over lake and ice (Up for review)
What would you have done differently?
  • Music
    Votes: 0 0.0%
  • Length
    Votes: 0 0.0%
  • Color grading
    Votes: 0 0.0%
  • Other
    Votes: 0 0.0%
  • Total voters
    4
MKurr
Adirondacks, Upstate NY
Site
www.youtube.com
So, I was driving by this lake and decided to film it. The fog covered the ice nicely, the lighting was OK (I did color grade), What do you think? Please comment constructively....
I like your work, and what you are doing is better than anything I can do. Really really great work. Im just gonna nitpick your fantastic job.
  • Try to keep clips the same length, or vary them and transitions depending on the music. I like to watch 6-7 second clips, it keeps my focus better. Anything more than that might require a transition
  • 1st clip - You might want to put a title on this clip, and even lengthen it a little bit to 20 seconds. You can also fade the music in.
  • Try to lower your yaw gain in DJI Go 4. It will make for smoother turns and clips
  • Try to make manual adjustments to keep your horizon level. If necessary, keep the "adjust gimbal window open.
  • At 2:12 you have a little prop noise visible on the left side. Was it windy, or in sport mode?
  • At 58-59s, it was a 1 second transition. Might want to extend the transition to 3-5 seconds. When playing soft, slow music, you want transitions to be more gradual.
  • At 1:28 maybe a slower transition
  • At 1:48 slower yaw
  • 1:52s great transition
  • 1:58 might want to transition to a different scene, instead of gimbaling up. I got a little dizzy
  • 2:10 how about closing credits or detail
I usually try to, but I just didn't have much material to work with here... I used (I think) all the footage I took...
Yes, sport mode...
At 1:48 slower yaw
Actually here I sped up the video...
Thank you for your advice! I'll keep this in mind when making my next video....
Yes, sport mode...
Your work is excellent. Dont change too much at the same time. Just one thing per flight, get used to that change, and you will be golden.
Reactions: MKurr
Sometimes I am afraid changing how the hardware works... I'll try though...
Reactions: Former Member
robinbuzios
