Foggy lens fix attempt
Kywon McCain
⭐Smooth Operator⭐
Baltimore City, Maryland
Hi. I have foggy lens after I flew out in the rain. It was a horrible mistake. I'm not buying a entirely new lens. I filled the gimbal cover with rice and attached it to the drone I'm hoping for the best
Rice in the gimbal cover is A BAD IDEA in my opinion. Shattered grain bits and dust may get into places they shouldn't. Silica gel packets are almost certainly better. Note packets NOT loose beads.
Handling / shaking the drone as little as possible and with the nose pointing down I would remove the cover and rice then wipe the inside of the cover clean and with care remove dust from the gimbal, perhaps by wiping with a Q tip damped with iso propyl alcohol. Try not to push dust or bits into anything. Vacuuming might work but I would be concerned about the vacuum nozzle grabbing the gimbal.
Reactions: RadioFlyerMan
Doc, you really need to read your drone's manual before you have another 'incident'. Like the bit that that tells you not to fly in the rain....
Rice is not a magical fix for moisture removal. It sounds good on Facebook or Twitter, but reality is a different matter.
Instead, try putting it in a warm, gentle airstream. The top of a refrigerator, especially one that's recessed into the wall, is a good option. The exhaust air stream from a computer is another.
And for some more unsolicited advice, remember that water and electronics seldom go together well.
At the most, I'd try a hair dryer on low/slow. Don't get the nozzle any closer that a foot and not directed at the lens very long at a time. Still have to be VERY careful.
What drone are you flying? I fly in the rain quite a lot and never had this issue with the air 2.
I only get foggy lenses when I bring the darn thing out side from inside and our humid air and have to wipe it a few times do to temp changes.
al3597
