Footage analysis help please
ufomg
Filming over the south coast of England today.
I noticed on playback that my footage has a weird 'jumpy' effect.
Please have a look at the video and help me solve the issue.
Is this the infamous in-drone noise reduction issue?
All the settings are zero in the personalisation menu.
Firmware up to date.
Rendered in Premiere with 'Match Source' to minimise any conversion issues.
Rendered at maximum depth, 2 passes VBR 40Mb
Here's the footage
I do see some jumping looks like a frame rate conversion issue.
Do you see the same on the original file?
I don't like the adobe match source you are better going through it manually.
The NR 'issue' just looks like smudgey areas in things like trees
Thank you for the reply.
Yes it's the same in the original footage.
TPS
