Free online DJI flight log viewer
is there an app that fills in the altitude between the flight path and the ground. It shows better the 3D view
You can see that view by opening the KML in Google Earth.
I released a new version of my log viewer today with the following changes:
  • Added support for processing Mini 4K flight logs.
  • Added support for processing Neo flight logs.
  • Removed the repeated “Auto returning to home” placemarks from KML while the aircraft is returning home.
  • Tips and warning messages that repeat in consecutive rows are now displayed once and not shown again until logged again later in the flight.
  • Some flight logs were populating the aircraft component serial number fields with unreadable characters.
  • Some battery fields were populated with a “0” when no data was available in the flight log.
  • Added support for processing Air 3S flight logs.
  • Added support for processing Specta Mini flight logs.
Reactions: davidarmenb
  • Added support for processing Flip flight logs.
  • Added support for processing Matrice 3TD flight logs.
  • Improved the message extraction logic to ensure more consistent formatting of tips and warning messages.
  • The "OSD.mileage [ft]" and "OSD.mileage [m]" fields now use speed data to calculate the distance traveled when GPS location data is unavailable.
  • Resolved flight log decryption issues that sometimes caused photo capture points to be recorded incorrectly.
  • Added support for processing Matrice 4E & Matrice 4T flight logs.
  • For drones with dual batteries, the serial numbers for both batteries are now stored in the SERIAL.battery and SERIAL.battery2 fields.
  • Serial numbers can be found in the RECOVER.*, DETAILS.*, and SERIAL.* fields depending on where they are extracted from flight logs. All serial numbers have been combined together and stored in the SERIAL.* fields. When referencing serial numbers, use the SERIAL.* fields as they now provide the most complete data.
  • Resolved an issue that prevented photo and video data from being extracted from Mini 2 flight logs.
  • Added support for processing Mavic 4 Pro flight logs.
askacfi
