From SF Bay Area, New Mini 4 Pro Owner
Welcome to the forum! :)
I'm a new drone user and decided the Mini 4 Pro
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Hey all, I'm a new drone user and decided the Mini 4 Pro had the features I've been waiting for all these years so I picked one up a few weeks ago... still haven't done my first flight yet though but planning it now.
Thanks!
Welcome to the forum from the Rocky Mountains of Colorado! Happy and safe flying!
Thanks!
Have Fun and fly safe! If you're looking for the best drone label on the planet, please checkout www.dronetat.com. Custom engraved tags with all your info that last the life of the drone.
Cheers and good luck with the new bird :)
Welcome to the Forum!
Do you any experience flying something with a remote?
A good day can go bad really fast, that is the easy part. :rolleyes:
For sure always stay a way from Mavic Magnets (🌲)
Rod ..
I'm not looking but ya' get me peeking 😏.
Just wanted to give a thumbs up on your product. 👍
Robby1983
