Hello, I recently bought a used Mavic, I was told at the time of purchase that the gimbal was broken, so after some research I found a gimbal used for sale, bought and installed on Mavic.
As soon as I put it on I noticed that the lens pointed up and moved to the right side, it is not aligned with the drone, okay I would then have to calibrate, I took advantage of it and I started by calibrating the IMU then the Compass and finally the gimbal and it's here that the thing runs to the crooked, to 52 € of the calibration process it gives error, which I notice is that yes yes the gimbal is perfectly aligned with the drone, but when restarting it again is out of position.
Can someone help me ???
Thank you
Thank you
